Results 1 to 10 of 18
Thread: do you think this will work it kinda getto
    May 2006
    Bakersfield,CA
    Ok i went down to the local hardware store and got some 3in PVC and some elbows to make a forced air induction or somthing like that any how here are some pics i used 3 elbows one 3in to 4in and 3 feet up PVC pipe and o ya i had to relocate my horn
    2006 1500HD Intake and HPtune,Cognito Steering kit, comp 218/224 cam
    1994 chevy P/U 1500 Sportside 330 H.O. Crate 4.11 Eaton posi. 150 Wet Nitrous Holly kit w/t external full cell
    E.T. 14.2@102mph on (20's)
    http://i15.photobucket.com/albums/a3...ure200X600.gif
    1994 chevy
    http://vids.myspace.com/index.cfm?fuseacti...eoid=1435245725
    2006 1500HD
    http://vids.myspace.com/index.cfm?fuseacti...eoid=1135635224
    DBYRD Guest
    it should work to an extent.
    Aug 2005
    St. Anthony, Indiana
    <div class='quotetop'>QUOTE(Lethalyoyo &#064; Nov 6 2006, 11&#58;12 PM) [snapback]72460[/snapback]</div>
    Those are your tranny cooler lines
    May 2006
    Bakersfield,CA
    <div class='quotetop'>QUOTE(foggy &#064; Nov 7 2006, 12&#58;27 AM) [snapback]72462[/snapback]</div>
    do you think it will melt the PVC
    E.T. 14.2@102mph on (20&#39;s)
    1994 chevy
    2006 1500HD
    Aug 2005
    <div class='quotetop'>QUOTE(Lethalyoyo &#064; Nov 6 2006, 11&#58;52 PM) [snapback]72464[/snapback]</div>
    nope
    Jul 2006
    College Station, TX
    That is a good install. I hate to brake it to you but that is just a very efficient cold air intake. You might ask how do i know. Well this is my third truck that i have built ram air on. Here is what i did and this may help you.
    1. Parts- 1 dryer hose from home depot, 1 dremel, 1 can spray insulation.
    2. I used the drimmel to make a hole in the bottom of the air box and in the metal plate below the air box.
    3. I slid the hose through the air box and down and through the support and then up behind the front grill similar to what you did.
    4. Now here is where i made it ram air. This took a little physics thought on my part. It is easy to pressureise a big space a little bit then it is a smaller place. What you do is with the spray insulation i sealed all the remaining holes in the sides of the air box to only use what the hose is bringing in.
    5. Ram air does not become functional until around 60.
    Now if you have any questions let me know.
    2004 EXC Silverado 6.2L
    Mods:
    May 2006
    Bakersfield,CA
    <div class='quotetop'>QUOTE(shwarmy &#064; Nov 7 2006, 01&#58;49 AM) [snapback]72469[/snapback]</div>
    throw some pics up if you can that would be cool
    1994 chevy
    2006 1500HD
    Jun 2005
    Round Rock
    Dale, Cowl327, has a great set up for the GMC Grill/Intake. See if he will share his innovative idea.... forced air without vaccuuming the ground/water
    08 HHR SS
    Jul 2006
    College Station, TX
    Jethro,
    Dont you have personal experience with sucking in your truck. HEHE just kidding your truck kicks ass. I cant wait to race you again and beat you. I hope.
    On a serious note jethro does your air intake have a chance of sucking in water since it is so low?
    Mods:
    May 2006
    Bakersfield,CA
    hey thanks every one for you imput it is better than the guys at GMfullsize all they do is talk shit i ges that goes to show that you all are into helping people not thrashing there ideas
    1994 chevy
    2006 1500HD
