Results 1 to 10 of 20
Thread: Help With Shackles Please!
    Aug 2006
    McCurtain County, OK
    I posted this in the mechanical forum, but got no response. Is there anyone that knows about these shackles? Or 2000 and up shackles in general?
    I recently ordered a set of McGaughy's lowering shackles like someone on here suggested. They came in today and the invoice says "88-98 chevy truck, 2wd, 1/2 ton." They are supposed to be for my '04 truck. Are they one in the same? Will they work on these year models as well as mine? Thanks in advance!
    2004 ECSB Silverado LQ9 6.0L Superchips;14.0 @ 96: 4900lbs of Fun
    69 Chevelle Coupe LS1/A4 swap
    Aug 2004
    Magnolia, TX
    i do believe all the shackles are pretty much the same
    Jun 2005
    Round Rock
    IMHO do not use shackles to lower the rear, they create pinion angle problems.... personal experiance. SCIV used shackles first and had problems. Now he has lowering springs and no problems. Besides the annoying squeeeeeking you will get a shudder, mine was between 15 and 40, not good.
    Nice ride
    08 HHR SS
    Oct 2005
    drinking your alcohol
    i did the shackle and hanger drop kit on my tuck...... honestly i dont see what the huge difference could be... they only took me bout 30 miutes to install with a floor jack on the ground.... try and fit em on there... if it doesnt work you havent lost much time and send em back for the correct ones..
    btw are you gonna make it down to the meet in Nov??
    DamnYankee: my nana failed
    Aug 2006
    <div class='quotetop'>QUOTE(TxStVanWilder &#064; Oct 21 2006, 08&#58;49 AM) [snapback]70514[/snapback]</div>
    Maybe. Has the date been set for sure and the location?
    Aug 2004
    Magnolia, TX
    we don&#39;t have an issue lowering ours b/c we have 1 piece drive shafts. those with 2 piece driveshafts tend to get a lil vibration
    Oct 2005
    Houston, Tx
    i have shackles.. no problems here. they all look the same. not sure about fit though. i would call a suspension shop. or where you bought them at and ask them.
    Aug 2006
    They Worked&#33; I installed them in about an hour with the help of STNGH8r(Thanks). Here are a couple of before and after pics:
    [b]BEFORE
    [b]AFTER
    BEFORE
    AFTER
    oh yeah man that looks really good
    Jan 2006
    Looks good. How about under accelleration, does it make a grinding noise fron the carrier bearing? I want to do mine, but I think I will go with the springs like SC?
    Jamest
    12 Sec. Club! SOLD
    SOLD***
