Results 1 to 10 of 32
Thread: drop?
    Mar 2006
    Houston
    how low can i go with 275/45/20 tires....anybody have an experience with it...i want a 2/4 and i think that should work but i want to know for sure before i order the drop....thanks
    2001 seirra 5.3L ex cab.-- 93 performance Nelson Tune,longtube pacesetter headers, ory, magnaflow with electric cut out, airaid cai, throttle body spacer, clear corners, 1400 watt system, 2 ifinity tens custom boxes, panasonic head unit, punch grill....sold :-(
    09 camry se v6....gotta have a gas saver while in college...still gets up and goes tho
    Apr 2005
    I have a 2/3 with 275/55R20
    Gone, but not forgotten!
    Oct 2005
    drinking your alcohol
    i have buddys that run the 275/45 with the 2/4... my truck ended closer to being a 3/4 or 5 with my drop and i can fit those on mine with no rubbage
    DamnYankee: my nana failed
    Mar 2006
    Houston
    thanks... did yall go with spindles or springs in the front?
    i went with spindles on my 2/4 drop, but i have 255/50 tires.
    Mar 2006
    Houston
    how much does a drop usually cost? ive been looking around and getting different prices and if i went with springs up front would it mess up my alignment?
    <div class='quotetop'>QUOTE(blackout00 &#064; Oct 12 2006, 06&#58;50 PM) [snapback]69117[/snapback]</div>
    i think with any kind of drop in the front your gonna wanna get your alignment checked anyway.
    Mar 2006
    Houston
    <div class='quotetop'>QUOTE(duckysbht &#064; Oct 12 2006, 07&#58;20 PM) [snapback]69125[/snapback]</div>
    i heard with spindles i wont have to....but with coils i will....but will see....
    <div class='quotetop'>QUOTE(blackout00 &#064; Oct 12 2006, 07&#58;32 PM) [snapback]69130[/snapback]</div>
    when i got the spindles put on, i couldnt necessarily notice from looking at it that my alignment was off, and nor would the truck "drift" when i let go of the wheel on the freeway. but i went ahead and got the alignment checked anyway so i wouldnt have any camber that would result in my expensive ass tires getting worn down in the wrong way.
    my drop cost me right around 450 with the spindles, and its not too much less with the springs. make sure that if you go with spindles you get the right size. i wanted to run my stock wheels and tires for a while before buying new ones, but i bought spindles that fit 17"rims or bigger and stockies are 16s. so when your purchasin it, make sure you get the exact ones you want.
    Mar 2006
    Houston
    ya the spindle for mininum 16" wheel is &#036;359 but the spindle for minimum 17" is &#036;260 did u have to buy new shocks for front or rear?
