Results 1 to 2 of 2
Thread: Help with custom fuel system
    Apr 2004
    i currently have a 2001 5.7 under the hood of my 2001 truck. what i'm looking to do is mount a fuel cell in the bed, and build the fuel system to work with the stock power i have now, but be streetable for 700-800 HP later.
    What i have:
    aeromotive a1000 fuel pump w/ -10AN ports
    aeromotive 100 micron fuel filter
    baffleless/foamless billet fuel cell
    to run this stock, will i need a new fuel pressure regulator? if so, can you be recommended? will the PCM have big problems with me changing up the fuel system this much? i'm worried that the tank is going to end up being a problem here...am i right?
    any other thoughts and comments are completely welcome.
    "hacked-up rolling deathtrap"
    Jan 2006
    Las Vegas, Nevada
    Unless you are worried about your regulator being a restriction to maximum flow once you are pushing your future 800HP,your regulator will work just fine for now. Also, your PCM doesn't give a hoot about your fuel supply. Your regulator keeps the pressure down to operating range and the PCM changes injector pulse width as needed to fuel the engine.
    1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 3.73 one wheel peel, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
    1968 Camaro 95LT1/4L60E lots o' mods Web Page
    1961 Corvette project.......... C-4 suspension and brakes, 02 LS1/T-56 awaiting installation Pics
