Do a LQ9 6.0L iron block build it up. Stock you can get 345 HP built up properly you can go to 400 plus, or go a 5.3L or 6.0L LQ4 and put a turbo on it or a supercharger I know 500 horses is what you really need. A built 6.0L and A turbo or supercharger is the way to go. This is just my opinion.
GOOD LUCK!
Jamest<div class='quotetop'>QUOTE(USMC09 @ Aug 2 2006, 02:01 PM) [snapback]59711[/snapback]</div>
Motor swap is most likely comin in the next year and i want to start buying parts....just wanted you guys opinions on whether i should go LS1 or stroke/supercharge what i got.....i definitely like the gas mileage on the ls1 better (i have to pull a boat), but id probably have to pay someone to do the swap ($$$$
12 Sec. Club! SOLD
SOLD***
