Results 1 to 10 of 12
Thread: OIL OIL OIL
    Jan 2006
    GOING TO WORK THIS MORNING AND THE ALARM FROM STS UNDER THE DASH GOES OFF AND MY AIRFUEL RATIO GOES OFF? i GET TO WORK AND MY ENTIRE BED UNDER NEATH IS COVERED IN OIL. I THINK THE TURBO SEAL WENT ASTRAY? THE TRUCK RUNS FINE, AT LEAST WITH NO OIL. HAVE IT PARKED AT WORK UNTIL FURTHER NOTICE. WHAT A BUMMER AND ON A FRIDAY!
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    San Marcos Texas
    Check your oil pump under the truck to see if it comes on. It should run for a second every time the key is turned on. It is more than likely that the resistor that makes the turbo oil pump went bad. I think Alton's truck did this once.
    Jan 2006
    <div class='quotetop'>QUOTE(GMCwantsLS1 &#064; Jul 28 2006, 07&#58;36 AM) [snapback]59247[/snapback]</div>
    Check your oil pump under the truck to see if it comes on. It should run for a second every time the key is turned on. It is more than likely that the resistor that makes the turbo oil pump went bad. I think Alton&#39;s truck did this once.
    I WILL LOOK AT IT AT BREAK. IF THE PUMP IS OFF WILL IT STILL BLOW OIL OUT THE TAIL PIPE?
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    San Marcos Texas
    <div class='quotetop'>QUOTE(Jamest &#064; Jul 28 2006, 08&#58;25 AM) [snapback]59250[/snapback]</div>
    JAMEST
    Yes. It doesn&#39;t pump oil to the turbo the engine does that, it returns the oil from the turbo to the oil cap.
    Jan 2006
    <div class='quotetop'>QUOTE(GMCwantsLS1 &#064; Jul 28 2006, 10&#58;00 AM) [snapback]59255[/snapback]</div>
    I TOOK THE TRUCK HOME AT 11 AND THE OIL PUMP IS WORKING FINE AND ALSO NO OIL BLOW OUT? I WONDER IF THAT IS A SAFTEY FEATURE.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    San Marcos Texas
    <div class='quotetop'>QUOTE(Jamest &#064; Jul 28 2006, 11&#58;49 AM) [snapback]59275[/snapback]</div>
    JAMEST
    Not a safety feature&#33; A turbo can handle 0 pressure on the seals but must have a constant flow of oil. If it were front mounted, the flow would be gravity feed back into the engine. Since we are rear mounted there must be a pump to return the oil to the engine or else it would pool up inside the turbo and spit out everywhere.
    Jun 2006
    Bumer, hope that dosent happen to me .
    Nov 2005
    ohio
    check your pipng bro, but i dont think youll have any oil in them, its best to carry a spare relay just incase it fails. I had my relay fail and my truck smoked like a S O B, it scarred the crap out of me, but i found the relay was bad and i bought some spares at auto zone. They are the same as the relays for driving lights.
    Jan 2006
    <div class='quotetop'>QUOTE(Tim Z &#064; Jul 28 2006, 03&#58;26 PM) [snapback]59288[/snapback]</div>
    thanks, i will get some tomorrow. my pump is working on high not on low and i found out as i was testing the truck after the clean that the battery is bad so i will pick up one of those tomorrow. scared the piss out of me when i gunned it and the lights dimmed and the motor started to shut down. i almost thought i was going to get that 402 sooner than i had planned.
    also, can you clean an O2 sensor?
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    San Marcos Texas
    I guess you are talking about the outside of the O2? I would think some electronics type cleaner would degrease or in your case deoil the o2. I would not soak it. Maybe just wipe it clean or car wash it.
