Results 1 to 9 of 9
Thread: tuner software?
    Mar 2006
    I bought an elm 323 trouble code reader.....I am only going to use this for reading my trouble codes and monitoring some things....what software would you guys reccomend to dowload to monitor everything, and is there any that I can use to adjust the shift points and simple things like speed limiter and revlimiter???
    any help is greatly appreciated
    thanks
    Aug 2005
    St. Anthony, Indiana
    Jan 2005
    Conway, AR
    HPtuners is the best by far! You can adjust every parameter available in the PCM.
    <div class='quotetop'>QUOTE(chrisj6 &#064; Jul 19 2006, 11&#58;20 PM) [snapback]58433[/snapback]</div>
    HPtuners is the best by far&#33; You can adjust every parameter available in the PCM.
    Is there anything else out there other than HP Tuners and Allen Nelson....?
    Get the best software first.... Don&#39;t find out the hard way..... Go HPT...
    2004 Nekkid Z71 Avalanche with increased traction, enhance aerodynamics, and upgraded airflow.....
    Mar 2006
    <div class='quotetop'>QUOTE(FlaBouy &#064; Jul 20 2006, 05&#58;56 AM) [snapback]58443[/snapback]</div>
    thanks for the info guys, do I need to buy all this software to go with my scanner or can i downlod it somwhere and if so where at. hp tuner, tunercat, i have heard good stuff about both but dont know how to get it, can any of you guys download it to me?
    <div class='quotetop'>QUOTE(carfreak07 &#064; Jul 23 2006, 12&#58;02 AM) [snapback]58735[/snapback]</div>
    I hope you are not attached to that scanner.....HPT scans codes, allows you to reset, and when you want/need to, you can turn them off or disable individual codes......
    Good Luck
    LTN....efilive is similiar, but they are having issues bringing their datalogger/software upgrades to market.... a lot of frustration on their forums right now......
    Jun 2006
    hey i really dont know anything about software tuners but what is the difference between efi live and hp tuners? thanks just wondering.
    Aug 2005
    http://www.hptuners.com/
    Sep 2003
    I have seen EFILive but I really like HPTuners better in my opinion.It is awesome stuff.
