Results 1 to 2 of 2
Thread: Just installed STS kit....what is that buzzer beeping at me?
    Feb 2006
    MIZZU
    Hello-
    Well we just got done installing the STS kit on my truck today and the wiring harness has this little buzzer/beeper that comes into the passenger compartment and also a little toggle switch with 3 wires going to it.
    I thought the buzzer was a warning that the oil pump was not working, but it is pumping the oil fine and I drove the truck for 45 mins (getting on it alot) and never smoked or acted weird.
    Everytime I floor it though the buzzer screams at me until I back off some then it stops.
    I flipped that toggle switch and I can hear the sound of the oil pump change like it is running high speed, but with the switch in either position I get the loud warning buzzer and it is annoying.
    Anyone have a clue what is going on and what that switch is for? My STS instructions say nothing about the switch but someting about the beeper being a oil pump warning.
    Otherwise the kit is awesome and the truck is lots of fun. STS rules!!
    Later, Ty
    1999 Silverado Z71 RCSB with 2006 LQ4 6.0, Comp Cams 220/220 581/581 115lsa, STS, methanol, Nelson street tune, 160* stat, 2006 E-fans, FLT 4L60. 12.53 @ 107 on 5psi
    Jun 2005
    Its the buzzer from the switch back by the oil pump. Pull the cover off, pull the rubber plug out of the top with a pick or small screw dirver and screw the allen head in (clockwise) half turn at a time until the buzzer quits going off. Can't remember what size allen wrench but I think around 7/32. May want to take a size either direction under there with you.
    '02 Silverado Z-71, STS Turbo @ 10psi, TRT Custom FMIC, Comp 222/218/115 cam, Patriot Gold Dual Springs, Hardened Push Rods, 60# injectors, 160 Thermo, FAL E-Fans, Nelson Harness, Yank 2600, Built Rock On VacMod 60E Transmission,Walbro 255 fuel pump, ASP Underdrive pulleys, Gibson Shorty Headers all polished up with a Nelson Street Tune
