Results 1 to 10 of 21
Thread: Cam on feel the noise! (? for Allen & TRT guys too)...
    Mar 2006
    Mesquite
    OK, cam isn't 'on' or in, but I WANT to feel the noise!
    I've decided on putting my $500 toward a cam. Here are my options as I see them: 1.) I'm going to have to buy either a used one, 2.) find a great deal on a new one, or 3.) buy a new LS6.
    With the LS6 there seems to be too much undecidedness about whether longer pushrods are really required, so I'd kind of like to steer clear of that (unless someone can convince me otherwise?).
    There are some used Thunder Racing cams on line, but I'm still learning all of the numbers and what they mean, so yeah, I'm looking for advice as far as which cams are good and which to avoid.
    This is my daily driver and I drive a lot during the day for work, so I don't want something loping to the point where it sounds like it's going to die. I'd like a nice mellow but noticeable lope that screams when you wake it up.
    So, sock it to me - whattaya suggest?
    PS: Allen & TRT guys - I'm open to having either of you install it, but I'd like the re-tune in person (unless you don't think it's necessary Allen?).
    Dec 2003
    Newark, Tx.
    around 220 duration on a 112 or 113. I wouldnt go anymore than something like the TR224 on a 112.
    224 cam
    You could always have a custom grind done, but with so many choices, I'm sure there is one waiting to be shipped to you.
    Keep watching for used ones, that way you can do springs at the same time. You do need springs.
    Apr 2005
    <div class='quotetop'>QUOTE(trtturbo &#064; Apr 29 2006, 05&#58;06 PM) [snapback]51644[/snapback]</div>
    224 cam
    You could always have a custom grind done, but with so many choices, I&#39;m sure there is one waiting to be shipped to you.
    whatabout the TR220 112 lsa??? or would you reccomend the TR224 112
    1999 GMC Sierra black reg cab short bed SLE Z71 5.3 <--CARDOMAIN PICS
    NELSON 93 hot tune, 02 PCM, VOLANT Ram air intake, MSD wires, ACdelco iridium plugs , Edelbrock ceramic shorty headers, jegs off-road y pipe, Dynamax int pipe, 3" Magnaflow Exhaust with turndown, EGR removal, throttle body bypass, vette servo, long servo pin, performance 4th apply piston, B&M shift kit, SLP 160* thermostat, LS1 Fans, NELSON harness, ported and polished throttle body (did it myself, for free lol)..... _______? cam is next as soon as i stop spending all my money
    Mar 2006
    Mesquite
    <div class='quotetop'>QUOTE(trtturbo &#064; Apr 29 2006, 06&#58;06 PM) [snapback]51644[/snapback]</div>
    224 cam
    OK...sounds good...
    Now how does that cam compare with the LS6? Should I even consider the LS6 or would it be simpler to just get a "name brand" one to take the guess work out of the push rod length of the LS6 (is that an issue or has that been resolved on here - seems to have been a lot of confusion)...
    Feb 2005
    <div class='quotetop'>QUOTE(BadBlackSS &#064; Apr 30 2006, 12&#58;30 AM) [snapback]51656[/snapback]</div> The first one was a nice video. lol
    2001 GMC Silverado
    Stock Bottom End LQ9, MS3, Stock 317's, Victor Jr, Aron's Elbow, 90mm TB, 1 7/8 TSP headers, FLT 4L80-E, Rossler Trans-Brake, 3600 PI TQ, 4.10's, 31" tire. Nitrous Dave System with Zex plate. On 150 shot 10.53 @ 128MPH 1.51 60'
    Old Setup = Trick Turbo Kit Tuned/Installed By Nelson Performance 10.78 @ 127.08 1.62 60'
    Mar 2006
    Mesquite
    Does anyone know what the HP increases would be for an LS6 cam and say a TR 220?
    Jan 2005
    Humble/Houston TX
    nobody is guna ask about converter size?
    loping to where it wants to die requires atleast a 3000 stall to keep it daily drivable. otherwise you have a cool sounding truck that runs like a geo metro, but dies everywhere also, its not just a cam that you can pop in. upgraded springs are the bare minimum for a cam like you want.
    i recomend ALOT of reading(search button) and you can probably answer your own questions from there. dont be afraid to ask questoions.
    old mod list: H/C/I/N/E/G 408
    Feb 2004
    Sour Lake Tx
    All i did for my cam was call Allen. Allen will hook you up. I would definately get springs and pushrods though cause i wouldnt trust the stock ones at 6400rpm where allen put the red line. From 5000-6400 my truck sounds like a NASCAR&#33; My truck pulls hard from 2600-2800 till 6400. I forgot what my cam was but if you want ill find the cam card for you and give you the specs. You will definately want a bigger stall though. You will notice less low end power.
    EATIN' FORDS AND TUNDRAS
    Jun 2005
    Round Rock
    Badseed91, what cam did you install?????
    08 HHR SS
