Results 1 to 7 of 7
Thread: Tranny Servos
    Jul 2005
    Loganville, GA
    I have seen the jet 4th gear servos and the Jet 1-2 servos and have heard yall talk about corvette servos and was wondering which one are reccomended and what the install is like on the because i have heard its not to difficult. Also what gains will i see or changes should i expect to occur when shifting
    Aug 2005
    <div class='quotetop'>QUOTE(Z71sierra7787 &#064; Feb 25 2006, 03&#58;21 PM) [snapback]45355[/snapback]</div>
    Don&#39;t know anything about the jet servo&#39;s. I put a vette servo in my stock trans. The term vette servo refers to the design of the unit. Larger surface area to apply more pressure on bands at shift vs the stocker. It isn&#39;t to difficult. Tedious. Not much room with the trans in, to put it in , or wasn&#39;t in my truck. Took a while to get it in and the c-clip back on cause I couldn&#39;t install it all together. I also had some trouble changing out the spring in accum to it. Holding it together and compressed so as to install the c-clip in it. Also a little trouble putting the final c-clip that holds the entire thing in. Was easier the second time around. It will firm up the 1-2 shift significantly.
    Feb 2006
    Not sure about the Jet servos or the Vette servos but I do have a TCI 1-2 Billet Servo and at WOT with the line pressure stock when it shifts your neck will snap. During normal driving the shift is almost instant also but not to harsh at least for me.
    http://i37.photobucket.com/albums/e6...2/1d89cfec.jpg
    Airaid CAI and MIT, Flowmaster 40 series catback, Jet 180 T-stat, TCI Billet 1-2 Servo, JBA blue plug wires, Westers 93 Hot Tune, EBC slotted frt rotors and pads, Centerline Stingray III 20s, Proxes 295/45s, Custom Paint, Plus a ton of other stuff&#33;
    Apr 2005
    hey KY do you know the quarter trick or the "bottlecap" trick makes it wicked easy
    1999 GMC Sierra black reg cab short bed SLE Z71 5.3 <--CARDOMAIN PICS
    NELSON 93 hot tune, 02 PCM, VOLANT Ram air intake, MSD wires, ACdelco iridium plugs , Edelbrock ceramic shorty headers, jegs off-road y pipe, Dynamax int pipe, 3" Magnaflow Exhaust with turndown, EGR removal, throttle body bypass, vette servo, long servo pin, performance 4th apply piston, B&M shift kit, SLP 160* thermostat, LS1 Fans, NELSON harness, ported and polished throttle body (did it myself, for free lol)..... _______? cam is next as soon as i stop spending all my money
    Aug 2005
    <div class='quotetop'>QUOTE(metalmulisha777 &#064; Feb 26 2006, 02&#58;33 AM) [snapback]45427[/snapback]</div>
    No I don&#39;t. Fill me in. Hope I&#39;m done tranny modifying for awhile but never know.
    Apr 2005
    "I also had some trouble changing out the spring in accum to it. Holding it together and compressed so as to install the c-clip in it." jut get a C clamp and 2 quarters (some ppl use bottlecaps,but quarters work fine, just be careful not to scratch anything) put the quarters over the center where theres a hole to protect the hole and compress it together with the c clamp then it makes it simple to install the c clip
    hey heres a website that has pics.... itl def show you what im talking about... i just used a quarter instead of a bottlecap but whatever they do the same thing by protecting the holes http://www.gmfullsize.com/Tech%20Pag...ServoTech.html
    Dec 2003
    or just use a bolt through the center hole with some washers and tighten it down to remove the c-clip
    2003 Arrival Blue Silverado SS.....I just can&#39;t leave &#036;hit alone.
