Results 1 to 10 of 13
Thread: TRANS GUAGE
    Feb 2006
    i have a sierra that i wanted to mount a trans temp guage in, check this out it took me sometime but i was able to make it work. I used 3mm carbon fiber for the backing. let me know what you think. (i may even patent this thing) http://i42.photobucket.com/albums/e310/nov...ge/MVC-041S.jpg
    Aug 2003
    Spring, TX
    that looks good.
    -leo-
    2009 Silverado CC - 6.0L L76|6l80e|3.42s|4/7 drop w/ helper bags
    01 silverado ecsb - (RIP 04/2009)
    Apr 2005
    looks like well be fighting ove that patent lol ... i did that with a peice of aluminum painted black like a year ago lol, does look sweet tho.... in the pic i got a little crazy with the armorall on it so it looks kinda weird on the top cuz of the flash on my camera causing glare.....
    the other pic is just a shot of my cab......
    1999 GMC Sierra black reg cab short bed SLE Z71 5.3 <--CARDOMAIN PICS
    NELSON 93 hot tune, 02 PCM, VOLANT Ram air intake, MSD wires, ACdelco iridium plugs , Edelbrock ceramic shorty headers, jegs off-road y pipe, Dynamax int pipe, 3" Magnaflow Exhaust with turndown, EGR removal, throttle body bypass, vette servo, long servo pin, performance 4th apply piston, B&M shift kit, SLP 160* thermostat, LS1 Fans, NELSON harness, ported and polished throttle body (did it myself, for free lol)..... _______? cam is next as soon as i stop spending all my money
    Apr 2005
    belton, tx
    Got my boost gauge there. Billy @ texas rear tubos (actually Dustin made it) built from carbo fiber.
    Great place for a gauge in my opinion
    2013 2wd Z71 6.2 crew cab
    Dec 2003
    Newark, Tx.
    I just supervised. You know, QA type of thing.
    Jan 2006
    Thats pretty cool looking.
    Jamest
    <div class='quotetop'>QUOTE(redsierra04 &#064; Feb 23 2006, 10&#58;01 PM) [snapback]45227[/snapback]</div>
    12 Sec. Club! SOLD
    SOLD***
    HotRodV6 Guest
    OK, i know this is an old thread, but im going to be picking up a 2005 GMC Sierra RCSB with a 5.3 auto and in the guage cluster is doesnt have the trans temp guage, and i know on the 99-02 trucks you could get a cluster from a 3/4 ton that had the trans temp guage and swap in the whole cluster, can you do this same thing with the 03-05 trucks as well?
    The only part number for a cluster i have been able to find is the 03 Silverado SS cluster with the white face and it has the trans temp guage, but is over 400 bucks.
    Spring, Texas
    Quote Originally Posted by HotRodV6 View Post
    Try this:
    eBay Motors: 2003 - 2006 SS Cluster Gauge, Silverado, Escalade (item 170166996709 end time Nov-14-07 09:38:58 PST)
    You will have to get the mileage programmed but it should work.
    Hutto TX
    used escalade/denali cluster???
    1991 Silverado ECLB
    LM7-T56
    look real clean man
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
