Results 1 to 10 of 17
Thread: Decided on the motor going to build
    Jan 2006
    San Antonio
    Ok decided on the motor I am going to build for big blue. It will be built by HOLLENDRIX MOTORSPORTS. The motor is going to be DE-stroked 4.27 experimental. The truck will be running a single exhaust, manifolds and a factory style Y-pipe. Yes you heard those correctly. I will give you guys more info as I get deeper into it. Oh and I will defenantly need to get that performance tune from allen with this one.
    David
    Hollendrix Motorsports
    Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
    Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
    EL JEFE
    ROUGHNECK
    Nov 2005
    ohio
    mmmmm. how many cubes is it going to be?
    Jan 2006
    San Antonio
    oh just a standard 6.0l
    EL JEFE
    ROUGHNECK
    Feb 2005
    Austin, Texas
    What do you mean 4.27? Bore or what. Why are you going to run stock manifolds with how you are going to want to spin a short stroke motor you are going to need all the exhaust flow you can get.
    Jan 2006
    San Antonio
    <div class='quotetop'>QUOTE(1slow01z71 &#064; Jan 29 2006, 07&#58;50 PM) [snapback]42634[/snapback]</div>
    Ahhhh we have a smart one I was wondering how long it would take someone to figure out about that. It will be a 427. 4.27 designation on the experimental engine. The exhaust will be factory style. Basicly you look at it and be like man that looks stock. But it is what is hiding under that sheeps clothing that is going to be the fun part. Now take in to consideration this vehicle will still be driven daily 100 to 200 miles if not more. This is going to be a durability test also on this engine.
    EL JEFE
    ROUGHNECK
    Feb 2005
    Austin, Texas
    So you are building a motor with a 4.125 bore with a stock stroke or what you have me confused or are you just building a damn 427?
    Jan 2006
    San Antonio
    cubic inch yes 427
    EL JEFE
    ROUGHNECK
    Feb 2005
    Austin, Texas
    so whats the destroked part?
    Jan 2006
    San Antonio
    no no DE - stroked
    EL JEFE
    ROUGHNECK
    Feb 2005
    Austin, Texas
    What does DE stand for? better go with a WIDE lsa for stock idle
