Results 1 to 7 of 7
Thread: Wanted: Injectors
    Nov 2005
    North Dakota
    I want a stock set of 4.8 or 5.3 injectors for my 2000 5.3. Show me what you've got.
    Brendan
    Nov 2005
    ohio
    I ve got injectors 4 U, from my 2004 silv,5.3, just replaced them with 44# for my turbo. They are just taking up space, shoot me a bid if you want them, i also got the stock fuel pump if ya need it.
    I also have a set of stock 5.3L injectors out of my 2004 Avalanche if you still need some. I pulled them to add 42 lb injectors with the Vortech S/C
    Let me know
    2004 Nekkid Z71 Avalanche with increased traction, enhance aerodynamics, and upgraded airflow.....
    Don't want to jump on his thread. But if the injectors will work on a 99 5.3 I would be interested.
    Price?
    Thanks
    Brian
    Feb 2005
    All the year truck injectors will interchange except for the ones that run on E85 fuel. The only thing you will have to do if they are different size in lbs is to have the PCM tuned for them.
    But they are all plug and play.
    New Truck on it's way: '07 Classic GMC 2500HD DuraMax LBZ
    03' Silverado ECSB 4x4 Z71 LQ9, TR230, Patriot LS6, 31lbs, Trailblazer stall, Corvette servo, Corsa Touring,
    HP Tuners
    SOLD - 99' Silverado ECSB 4x4 5.3, Edelbrock RPM, Nitto Terra Grapplers, Texas-Speed Tuned 02' PCM, LT1 fans
    england uk/San Diego
    any of u guys still have those stock injector for a 5.3
    the injector in my 00 5.3 are starting to stick again, and this is my daily driver and the only vehicle i own so it has to run, i can't have it break down because my wife has to go to skool at night
    and how much are u guys looking for them?
    new project
    37 m-series 3/4 ton chevy truck,
    plans: 5.3/4l80e, cut down ford 9 inch, 6piston brakes
    <div class='quotetop'>QUOTE(joakwin &#064; Feb 15 2006, 01&#58;14 AM) [snapback]44495[/snapback]</div>
    the injector in my 00 5.3 are starting to stick again, and this is my daily driver and the only vehicle i own so it has to run, i can&#39;t have it break down because my wife has to go to skool at night
    You have PM. I will have a set of 8.1L Marine Injectors (42#) next week. I am installing 60# with the head/cam package.
