Results 1 to 10 of 11
Thread: Bigger alternator for E-fans
    Aug 2005
    Spring, Texas
    I recently purchased a 34" Radiator, 05' E-fans, and a Nelson Harness. But, I read somewhere that you might need a bigger alternator?
    I have no clue on this.
    The only thing i got goin for me is a Optima Yellow Top Deep Cycle.
    06 TrailBlazer SS LS2 4.10's
    02 SC StepSide Factory Orange
    Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
    07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
    Jun 2005
    Round Rock
    You definitely will need the 130 or larger for the '05 fans, also get the larger belt before you get back from the store....
    Do a search, some one already listed out the parts for the upgrade....
    08 HHR SS
    May 2005
    Everything I have read is exactly what Jethro_3 said.
    130 or larger.
    http://memimage.cardomain.net/member...607_2_full.jpg
    4-6 drop, 18" Centerlines, K&N FIPK, Flowmaster 50's dumped, Transgo HD-2 shift kit, vette servo, billet OD servo and Nelson tuned, 160* T-stat, Eaton posi and 4.10 gears.
    Aug 2005
    Spring, Texas
    Should i go aftermarket or get a bigger Delphi Alternator from a dealership?
    Jul 2005
    modesto, ca
    Don't quote me, but I head the only differance between the 105 and the 130 was the pully size. Does any body know if this is true?
    http://i10.photobucket.com/albums/a1...dited-copy.jpg
    2007 Sierra crew 5.3 4wd, stock for now
    2004 Sierra scsb 5.3 - sold
    02 Z28 SLP cold air pack, Corsa exh, Center Force dual friction + 23 lb flywheel
    66 Chevy C20 (collecting dust)
    Aug 2005
    Spring, Texas
    I have heard if you put the smaller alternator pulley on you will get better amperage because it is turning faster, on the other hand it is also turning like a friggin' work horse....
    Jun 2005
    Round Rock
    The casing size is different on the 105 & 130. And the puley size also. I had to replace my 105 on my '01 Silvy after it puked on a Friday on the way home from work. Get an AC Delco, the other 2 from the parts stores shit on the way to the parts store, less than 10 miles new.....
    08 HHR SS
    Apr 2003
    Mansfield, Texas, USA
    False info. The unit is larger and requires a longer belt.
    E-fans require a larger alternator.
    130
    145
    160
    Are the amperages I recall available.
    Aug 2005
    Spring, Texas
    I called G and R Autoparts, where i bought my e-fans and radiator from. They had a 145 amp alternator for sale off a 2003 tahoe and they want like $100 for it. This seems like a good deal being that the guy said it has only 2 miles on it and guaranties it to work.
    What would you guys do? as far as brand and amperage?
    Thanks
    Jun 2005
    Round Rock
    Sounds like a good deal, how long is the gaurantee? Get a picture of the exact unit you would be buying. They ar very reputible. A rebuilt AC Delco 145 around here is above $180 with 1 yr warrenty.
    Just Do It....
    08 HHR SS
