Results 1 to 1 of 1
Thread: Carbed 4l60e 96-2006
    Jun 2015
    Houston
    Hey guys just finished my 5.3 swap in a 1997 silverado ext cab. I changed crank,rod and cam bearings, wasnt hard at all. But the most exciting part was the carbed 5.3 shifting perfectly the way it should without buying the tcm!! I used a quick fuel hr580 flipped the carb around I used the holley tps bracket, the sensor fit right on it since it was on the driver side. The tps bracket will need to be modified to fit the quick fuel choke. The holley choke and qft chokes arw the same except the qft choke is slitly turned or rotated and tps needs to be modified accordingly. The only thing thing that needs to be hooked up for the 4l60e to shift is tft,tps, vss and tach signal to ckp(crank),
