Thread: Wiring issues
    Jul 2017
    Wiring issues
    Hey everyone, my name is Bohdi. I'm swapping a 5.3 from a 2001 tahoe into a 1993 chevy 1500. I'm currently having some wiring issues. I'm not sure how to wire the trucks bulkhead wiring into the 5.3 fuse block. I need to run the trucks ignition to the 5.3s fuse block/pcm to give it power, but I'm not sure how. Any advice would be appreciated.
    Mar 2016
    BC Canada
    Go to lt1swap.com
    All the info you could ever need. I threw the 5.3 fuse block in the garbage and just ran everything into my factory block. A multimeter and a test light are your best friend
    1995 rcsb c1500, 4/6 drop, 5.3 L33, 5spd, 219/228 112LSA cam, LS6 springs, 799 heads, long tubes, magnaflow mufflers
    Mar 2017
    Nampa, idaho
    Quote Originally Posted by Bohdi F View Post
    All you need is the pink ignition wire from your stock truck fuse block to turn on the fuse block fuses and relays
