Thread: Lq9 computer question
    Apr 2017
    Northeast Ohio
    I just bought a LQ9 6.0 Liter from a 2005 GMC Sierra Denali. I bought it from a junkyard and the motor didnt come with a computer. I am wondering what computer should I look for?
    Mar 2016
    BC Canada
    One with blue/green connector to match your harness
    1995 rcsb c1500, 4/6 drop, 5.3 L33, 5spd, 219/228 112LSA cam, LS6 springs, 799 heads, long tubes, magnaflow mufflers
    Apr 2017
    Northeast Ohio
    Do you have a model number for the ECM/PCM? I have a 0411 that I swapped onto the 5.7 Vortec I'm wondering If I can use that.
    I do not believe the 0411 is interchangeable with with the connectors you are using. It might be easier to convert your LQ9 into a drive by cable set up and modify your 5.7 vortec harness to work with it, rather than trying to swap in the new harness.
