Results 1 to 10 of 10
Thread: Nv3500 vss signal to pcm
    Mar 2016
    BC Canada
    Been driving my truck for the summer now, but I never did get my speedo working in my 95 c1500. I've wired both wires coming out of the vss on my nv3500, straight to the pcm (I think the wires are ppl/wht and grn/blk)
    What did I do wrong? I don't even think the pcm is getting a signal
    Sep 2011
    did you use a stand alone harness for your conversion??
    Mar 2016
    BC Canada
    I made my own stand alone harness from the 06 truck harness.
    Sep 2011
    did you leave all the 95 wiring intact and on the truck as well?
    Mar 2016
    BC Canada
    Most of it. I removed all the wires that went to the old tbi fuel injection stuff. I still have the old ecm in the truck
    Sep 2011
    On your green plug Pin 20--LT GRN/BLK VSS Low Signal and Pin 21-- PPL/WHT 821 VSS High Signal,,,, these wires should be connected to the VSS on the trans then you can connect Pin 50 on the green plug to the wire that goes to the cluster than controls the speedometer...
    Mar 2016
    BC Canada
    Ya that's what I have done so far but I'm not getting a reading to the PCM. The speedometer worked fine before my swap so I have a hard time thinking it's bad now...maybe it is bad. Truck will be parked for winter next week so I'll dig in and troubleshoot then. Thanks for your help
    Sep 2011
    Did you try leaving the VSS hooked to the stock wiring and see if the speedo worked as it always did?
    Mar 2016
    BC Canada
    No I haven't tried that. I'll have to look at the wiring diagram and try that
    Sep 2011
    I'd wire the VSS back into the stocks 95 harness and see if it worked that way...
