Results 1 to 5 of 5
Thread: spedo help
    May 2016
    spedo help
    I have searched and dont see an answer maybe sombody can help I have a obs 2000 2500 2wd just did a lq4 swap kept the original 4l80 I have a swap harness with the speedo wire but where do I hook it up to everything else works fine gauge wise just cant figure that out any help would be great Thanks
    Sep 2011
    You can run the wire from your swap harness through the firewall and hook it to the wire for the speedometer on the cluster plug..
    May 2016
    Ok thanks I will try that this weekend
    Nov 2009
    SAN ANTONE
    did you get the speedo working?
    May 2016
    never did been busy workin to much any input
