Thread: TAC module problems
    Mar 2016
    BC Canada
    TAC module problems
    So I've mounted my tac module on the drivers side firewall on my 95 for the dbw. Problem I have is it doesn't work when it's mounted, if I remove it and try it on another truck it works fine. Ive tried three of the stupid things and the only way I can get one to work is by having it just laying in the engine bay.
    Any ideas ?
    Mar 2013
    Long Beach California
    sounds like bad connector or some loose connection on the harness that makes a better connection when you lay it down. id search for bad connections/wires
    CALI LEGAL ENGINE SWAP!
    Mar 2016
    BC Canada
    Thanks I'll investigate closer.
