Results 1 to 10 of 25
Thread: 5.3/5.7l 72mm turbo truck dyno results
    Mar 2013
    Edmonton, AB, Canada
    So here is what I have in the setup:
    607HP and 638lb*ft @ 13lb boost
    Engine:
    -5.3l bored to 5.7l (Thompson Motorsports)
    -799 heads(LS6 head)
    -ARP head bolts
    -Forged Probe Pistons 3.902" flat top
    -TMS Moly rings
    -4340 Forged scat I-beam connecting rod w/ ARP 8740 rod bolts
    -King racing bearings
    -Melling high pressure relief oil pump
    -Wiseco .060" head gaskets
    -7.400" Comp Cams Chromoly Push Rods
    -LS7 lifters
    -.660" Trick Flow dual valve springs
    -Titanium retainers & locks
    -TU1 Custom Grind cam(spec speed.inc)
    -5.3l(LM7) rockers
    -"Muscle Car" oil pan
    -All other parts are stk 5.3l(LM7)
    Turbo:
    -72mm .96ar journal bearing Magnum Turbo
    -CX racing intercooler kit
    Fueling:
    -Aeromotive 340 stealth in-tank
    -Aeromotive a1000 fuel pressure regulator
    -Professional products fuel rails
    -60lb/hr motron injectors
    -dual nozzel water/meth injection (devils-own) DO3 + DO7
    Watch the Failures, build, and dyno runs here:
    https://www.youtube.com/watch?v=Rm_VprOaaAM
    Back Alley Motorsports 98 GMC
    -5.3l LM7 bored to 5.7l Thompson Motorsports -72mm T4 Magnum Turbo
    -TU1 Custom Grind cam(spec speed.inc) -799 heads
    -.660" Trick Flow dual valve springs -Forged Probe Pistons 3.902" flat top
    Mar 2013
    Special Thanks to the following:
    Back Alley Motorsports(Kevin, Dale, Derek, Brad, Kale, Brett)- Electrical, fabrication, installation
    Cougar Paint and Collision(Eileen, Graham, Gordon, Heather, Rod)- Paint and body work
    HP solutions(Neil Richards)-Technical advisor
    Daves Auto Ltd.(Gursimer Hansra)- Diagnostics
    lt1swap.com(Brendan)- Technical advisor
    ls1truck.com(farmtruc, capricefrk013, mickeymotormount, kewljay223)
    Additional thanks: Steve Bullerwell, Vance Bindon
    Here is the cost breakdown. I pretty much listed everything. Total is about $16,000 into the swap. These snapshots arent the greatest- if you want copies just let me know
    Damm nice setup, what the hell happened the 2nd time?
    Mar 2013
    Thanks man. Hard to say, I sent the block back to Thompson and they didnt have a clue what could cause that much damage. I had my engine guy also have a look and he couldn't give me a definitive answer either. So I'm assuming a bad casting??
    lots of hard work and its finally paying off congrats
    Dec 2009
    DIrty south AZ
    Nice Set up and great numbers, My set up dam close to yours made 600/656 on 13lbs, glad to see another 5.3 getting er done with the cx turbo
    Built 2 Run! 6XX HP/ 6XX TQ
    Mar 2013
    Thanks alot guys. Really appreciate it.
    The CX turbo is essentially a copy of the magnum?
    Dec 2009
    DIrty south AZ
    that im not sure? seems alot like it tho? i doubt ill switch to something else price is great and spools hella fast
    Dec 2009
    DIrty south AZ
    any track times yet?
    Mar 2013
    Quote Originally Posted by darnie1987 View Post
    Went 12.34s @ 120.10mph
    I didn't build a lot of boost at launch. I kept rolling on the brakes. With line lock I could prolly drop to mid 11's
