Thread: Driveshaft questions on 93 4x4 blazer/tahoe
    Sep 2011
    Planning on doing a swap on my friends 93 blazer/tahoe,, 2 door 4x4... it has the orginal stock 350 and trans... we have a engine ,, 5.3 and trans 4l60E with manual transfer case from a 2000 model truck,, with dirty dingo mounts.... should this drop in without having to make any mods to the driveshafts??
    Also will the 2000 model manual shift transfer case require mods to work with his stock t-case shifter??
    Jan 2014
    If its the one inch set back mounts, then the transmission will remain in the stick location. If it isn't the 1" set back mounts then the trans cross member will have to be moved, front shaft shortened and rear lengthened.
    Sep 2011
    thanks,,, we should be in good shape!
