Thread: rear suspension set ups
    Dec 2013
    Looking for better traction.
    I'm getting nitto drag radial on 17x7 steel wheel.275/40/17
    My buddy got me talk into welding braket lower portion rear axle setting below axle. Run cross member towards the cab. Adding adjustment bracket to the cross member. Attaching the two with tractor heim rod ends (not exactly sure the name of those adjustable heim rod) also talking bout wedgeing leaf springs adjusting pinion angle.
    What are guys running? See a lot of cal Tracs I hear lot more for wheel hop
    Hope Mills, NC
    why dont you just get some assasin bars and double adjustables and let her chew
    2005 GMC RST *sold
    2006 Silverado SS with nawz
    Dec 2013
    That would be too easy.
    Really looking to have something that works just as good be different than just a bolt on set.
    Hopefully work better. Hand made and have about $100 in it.
    00 rcsb, ls1, cammed, 4l80, 40k tru cool cooler, 3600 stall, 4.10, 3'' exhaust, LT headers, tunned, truion upgrade, 918 springs, e fan, 2" drop, M&H drag radials
    14 CAMRY DD
    03 ccsb cummins, 4'' straight exhaust, fass 150, smarty jr programmer wifes DD
