Thread: Shift Linkage
    Shift Linkage
    So what are most folks doing for linkage when swapping a LQ4 and 4L80 in a 94 sbrc. I have the stock non cable linkage rigged to work somewhat but the clocking is off for the indicator.
    Thanks
    Sep 2012
    Quakertown, Pa.
    The "clocking" is adjustable. It is cable mounted to the shift handle collar. It can be slid along the circumference of the collar to get the indicator to line up with the letters/numbers in the shift indicator.
    When I swapped my engine/trans in, I used the original bracket mounted on the old 4L60E. It had to shorten it in depth to accomodate the shift switch mounted on the new trans.
    John
    Dec 2011
    Savannah, ga
    i did this lol
    cut a notch with a grinder bent it and welded it back
    1997 RCSB, AES 390 + 4L80E transplant, F1A Procharger, #160 injectors, Magnafuel 750, Schoenfield Longtubes, 3" flowmasters, Steve Morris Bullit cam, Circle D 3k stall, Ford 9" rear, Homemade Caltrac bars.
    Quote Originally Posted by hollywood63 View Post
    Thanks
    You should be able to adjust the shift position a bit in two places.
    1) You can play with the attachment points on the shift linkage
    1B) You can reef on the shift rods and puts slight bends into them to align the shift needle to gear position
    2) You can play with the little nylon wire that goes between the shift bowl on the column and the gear indicator.
    HTH.
    Mike
    http://kds-performance.com
