Results 1 to 9 of 9
Thread: Cam question
    Cam question
    Doing a 5.3 swap onto my 84 gmc c10. I am going to use my 700r4 with the 2800 stall converter I already have in the truck. The old 350 had a comp 280 cam in it and I loved the way it sounded. What would be a good cam to put on the 5.3 that'll sound pretty aggressive and be good with my setup?
    Aug 2012
    Mount Pleasant, Tx
    I would run something along the lines of a 218/222 on a 112 LSA, using the EPS lobes. Straight up or advanced as much as 4 degrees depending on how soon you want the power to come in.
    Other options are:
    220/224 using the XE lobes
    219/223 using the LSL lobes
    You can go more aggressive but it will not make the power where that 2800 stall needs it.
    2000 GMC Sierra 1500 RCSB 2wd - 454 LSX powered drag truck...
    What valve spring should I use with the lsl lobes
    Aug 2012
    Mount Pleasant, Tx
    Either the PAC 1518's or a good double spring.
    Personally I would go with the EPS lobes and PAC 1518's, quieter valve train and longer spring life with basically the same power.
    Dec 2009
    DIrty south AZ
    u could got with a tr 220 on a 112 it will have a nice lope and you can run ls6 springs and you hav a good converer fo it too...
    Built 2 Run! 6XX HP/ 6XX TQ
    Jul 2009
    anything with an intake lobe between 216-220... exhaust lobe with a 4* split (216/220 or 220/224 for ex) gives a little extra high rpm (peak power) without killing the bottom end. I'd do a 220/224 XER on a 112+4.... old aggressive lobe i know but proven.
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
    Forgive my ignorance with cams but what is the + 4.
    Is that advancing the cam 4 degrees?
    Apr 2013
    Houston
    Quote Originally Posted by slow_01tahoe View Post
    Yes
    Aug 2012
    Mount Pleasant, Tx
    What he said^
