Results 1 to 9 of 9
Thread: cam shaft can be bent?
    Roma Tx.
    is there any possible way that a cam (cam shaft)
    can be bent?
    Sep 2011
    Not saying it can't happen but cams are made of cast iron and they generally break instead bending.
    99 rcsb silverado...... boosted.
    Roma Tx.
    Quote Originally Posted by jansen View Post
    i got a cam and theyre saying its bent because it fits and everything but at the end u have to hammer it in so it can go all the way in could it be the bearing
    Sep 2011
    Take it to a machine shop and have them put it in a lathe and run a dial indicator on it to see if its bent. If its not bent I would be looking at the bearings.
    Im gonna say wrong bearing or the bearing has a bur on it, and if it was the machine shop hammering on your cam to get it to go in, I believe Id find a new shop.
    Apr 2013
    Houston
    Quote Originally Posted by Botlfed View Post
    ^^^ xx2!!! Most likely since the last bearing is usually the hardest to get in it could have been burred on install. If it was bent it wouldn't have gone al the way to the back. On the other hand it's possible but not likely the factory cut was off. Was this a used cam or new cam
