Thread: 4l80e pump cover bolt o-rings
    Mar 2013
    Long Beach California
    so when i took the front seal off to replace, i checked out the bushing on the pump cover and it was shot. so i pulled the cover and got a new bushing pressed in. i see all over the place that the o-rings on the cover bolts should always be replaced once removed. i dont want any hassles and the used ones look pretty....welll... used... lol
    none of the local dealers have any in stock and it seems that they dont sell them seperately. it looks like i will have to buy the bolts too which is unnessesary. i was thinking about going to ace hardware or similar type store and getting some that matched cuz it would be faster and cheaper im sure than through the dealer. but idk if they are rated for the heat that these pumps produce.
    anybody have any suggestions? would ace be ok? if i have to order them, where can i get some that dont come with bolts? thanks!
    CALI LEGAL ENGINE SWAP!
    Mar 2013
    i found a few places online that sells them. bulkpart.com has them but shipping is rediculous. transpartsonline.com is where i ended up getting them from. shipping still sucks but was less. so in case anyone else is looking here is the site.
    http://transpartsonline.com/tpfile/t...PartsType=4L80
    13 bucks shipped
    Mar 2010
    San Antonio, Tx
    Im sure the ones from Napa or somewhere would be just fine to match up. The dealer has them, they just don't know how to look. I had to get my turbine shaft oring from the dealer and it was a bitch. I asked for someone that had been there a long time.
    2002 ECSB 2WD 5.3
    1995 Formula Firebird 383 LT1
    1984 Camaro 408 SBC
    Most sports require one ball, motocross requires two.
    Racing isn't a matter of life and death, it's much more important than that.
