Hello guys, I'm new here and my first time posting to a thread. Hopefully I'm welcome even though i drive a camaro.
Anyway I'm going to pick up a 2002 crew cab 2500 with a lq4 that has been rolled over and totalled out. I bought it for $1000 but have to give the tranny and transfer case back, still a good deal in my situation since they are of no use to me. I plan to swap the lq4 into my camaro. I have done quite a bit of research and think I got most things figured out. I have all the wiring diagrams and im going to make my own wiring harness. I have a 1980 camaro that I've given a pro street feel to and will make a toggle switch board for fuel pump, fans, ignition, push button start, and what not. I plan to use my turbo 350 with 2800 stall convertor, starshifter. 3.73 gears. detriot locker, 26in MT Drag radials. All of this was behind a 383. The 6.0 I will keep completely stock but will have longtube headers, 3 in exhaust, flowmaster 44's, and cut outs.
Well here is my questions. I live in montana where there is no emmision testing or regulations, so i don't need cats. What do i do about the down stream oxygen sensors. Does it just run in open loop or can the pcm just be reflashed to not worry about convertor efficiency. I know i have to get it flashed with m6 so ill be sending off the pcm anyway.
Next question is that i want to get setup to run nitrous when i have the money...then hopefully my pipe dream a turbo someday. I will probably go with a wet system intake tube fogger with TPS control. I plan on using the corvette filter and regulator for a returnless system. To be honest the whole fuel system is above my head right now and i should probably do some more reading. I just want to make sure what ever I do can at least supply enough fuel for a 150 shot.
Any help is welcome thanks, kurt
