Results 1 to 10 of 13
Thread: Custom a/c bracket suggestions for an OBS compressor on an LS motor
    Hey guys. I have a 1994 c1500 that had the old 4.3 V6 and have already dropped in the 5.3 in it. I am in the process of bolting on the accessories and using the 5.3 truck accessory bracket. I have the power steering and alternator taken care of. Now I am trying to get my older a/c compressor to be driven with the serpentine belt. I have a link below and I think it would work using the old 4.3 a/c bracket with a bit of modification. I would need an inexpensive way of doing it as I don't see myself spending $300 for an a/c bracket , which it outrageously overpriced, imo. Let me know what you guys did on your set up and what belt (or part number) you guys used thanks !!
    http://www.gmt400.com/forum/showthre...on-an-LS-motor
    Jan 2012
    warwick ny
    Checkout the holley bracket .
    Aug 2009
    New York
    Sep 2012
    Quakertown, Pa.
    This idea definitely works. I did it on my 6.0 swap in my '93. I had to change a couple of the smaller idler pulleys for the belt to clear itself on the water pump. I did it as described and it fit like a glove. It also didn't affect my hoses as I've heard some aftermarket brackets do. It did require a small amount of tweaking of the round bar braces to get the belt alignment just right. Here's a pic of it in place.
    John
    San Marcos Texas
    Why do you want to keep messing with those old power robbing noisy junk?
    Quote Originally Posted by GMCwantsLS1 View Post
    Its Miami !! Its hot and humid as hell down here 365 days a year 24/7. I will never drive a car or truck down here unless it has a/c, its a must.
    Quote Originally Posted by Mickeymotormount View Post
    Thanks. What belt did you end up using?
    Sep 2012
    Quakertown, Pa.
    Quote Originally Posted by droopyzda1 View Post
    The belt I used was a Gates Micro V KO61080. Depending on which small pulleys you use, your belt application may be a shade larger or smaller.
    When I was in the junkyard, I pulled a bunch of different pulleys off some GM cars. Not sure which ones I used, but I sized the belt accordingly. This belt size should get you close with the recommended pulleys on the linked website.
    John
