Results 1 to 10 of 18
Thread: Meth?
    Dec 2009
    DIrty south AZ
    Meth?
    U have a 2004 lm7 with a set of more or less prc 2.5 heads milled. 018 with a match intake manifold, tr 220 cam on 114 lsa. Im going to be runnin a cxracing 76mm turbo with a 1.15 AR. Im hoping to push 10-12 psi on 91a octane "- all we got here" im wondering if adding meth would be worth it?
    Oct 2006
    Wichita Falls Tx.
    Methanol helps if you have a heat issue or octane issue.
    Most use it as a safety thing.
    We sale the devils own kits. If your interested pm me.
    Simply the best turbo kit for late model GM trucks.
    Custom fabrication to fit your budget and needs.
    Dealers for Precision, Comp. & Magnum turbos.
    Online Store
    [/CENTER]
    Dec 2009
    DIrty south AZ
    ya, i ben debating on getting a kit, im limited to 91 around here and so idk if id need it for it using 10-12 psi?
    Built 2 Run! 6XX HP/ 6XX TQ
    Oct 2006
    Wichita Falls Tx.
    Low octane to begin with. 10-12 might not be a good idea.
    Start low and flow a d walk up on it.
    Otherwise it will be short lived.
    Online Store
    [/CENTER]
    Arizona/Utah
    Your best option would be to take a trip down to Tucson or Phoenix. Bring back 100 gallons or so of 100octane fuel. Then mix 2 gallons of 100 with 8gallons of 91 which would result in about 94octane. You only drive that truck 3000 miles a year. Assuming 10mpg you will go thru about 60 gallons of 100octane per year. Thus saving you from needing to pay for a meth system or fluid. If you feel like you need more than 94 oct then up the fuel mixture with more 100 until satisfied. Right now there is a shell station in Phoenix selling 100 octane for about $4.80/gallon. A place in tuscan even does 4.50 when you buy more than 5 gallons. Though it varies with up to 7.99$/gallon.
    Dec 2009
    DIrty south AZ
    isn't this the point of the form? to ask questions. and i try and research but i dont currently have the internet at home so i have to on my 15 min lunch break. neways im going to have it live tuned by a guy in tucson, im just wondering if meth would be worth it. i plan on starting out around 7 psi for now then slowly upping it. i wan to try and get 10-12 psi i understand its hard with 91 but i also know meth will cool, and allow more timing to be added but is it safe to rely on it?
    Pittsburgh, PA
    if you go with a meth kit go with a good quality kit. A good kit doesn't use push lock fittings or nylon tubing
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Dec 2009
    DIrty south AZ
    i was looking at getting a devils own stage 2 kit from tricks if i get one? im just trying to safely get what i can from 91 gas since its pretty much all i can get my hands on around here. as far as the tune. i know it will be a spot on tune.
    Arizona/Utah
    There is no doubt meth is cheaper than race fuel, but it costs what $600 minimum for a proper setup? The cooling effect is also great, buy I feel like the extra complexity isn't worth it for this build. 12lbs+ I could fully understand the desire for meth, but for a 6-8lbs I don't see it as necessary. A little higher octane fuel will make it work just fine. A good tune should make it run well and safe without needing meth on top of it.
    Pittsburgh, PA
    12psi in my experience netted me 130 mph traps..........12 psi on a small turbo will create heat that isn't needed in the motor. race gas is more expensive in the long run then a meth kit
    c16 $14-18 a gallon
    412 Motorsports
