Results 1 to 10 of 15
Thread: No Reverse
    Aug 2012
    Hibbing,MN
    No Reverse
    K I did an LQ4 swap and am using my stock 4L60E and I have no reverse. Have hooked up the Tech2 and found my PRNDL switch shows the gear change. But the Trans Fluid Pressure switch shows Park, Neutral, Neutral, Drive4, Drive3, Drive2, and Drive1. Could it be in the valve body when I did a rebuild? PLEASE SOMEONE HELP ME WITH THIS!!! I need my truck back!!! My GTP spun a rod bearing so I haven't had a car for the last couple weeks and am sick of F'n walking!!!
    any dtc's? that will let you know if you forgot to plug something in.
    maybe a torn gasket, leak, etc.
    after a rebuild, sometimes that reverse pin is the issue, had that happen before.
    if you can't find anything on the outside, just say ... and pull it back out and tear it down.
    Aug 2012
    Hibbing,MN
    no dtc's and i'm hopin it not a torn seal cuz i really don't wanna do any more removal then I already have
    it's only funny because i've been there, hahaha.
    it'll give you something to do over the weekend, oh boy what fun!
    Aug 2012
    Hibbing,MN
    I would work on it over the weekend but it's stuck in a stall at school... sucks!!! But i have excellent resources there Alldata, Mitchell, Tech2, all kinds of fun stuff like that. HPTuners only gets me so far for what I'm workin' on.
    Aug 2012
    Hibbing,MN
    K so i came across a deal for a 80E 10,000 miles or so with no converter. Tradin the GTP for it. For my basically stock set up would you suggest just a stock converter? or Would you get something from the aftermarket? I am tryin to go cheap.. Ideas...???
