Results 1 to 10 of 17
Thread: wheel speed sensor and brake booster delete
    Sep 2011
    Well I've almost got my engine out of my truck ( bell housing bolts and motor mounts holding it in) and I'm wanting to clean up things that i don't need on the truck. Plans are a forged 370 with twin 76mm's and I want it to be of show quality this go around. I'm cleaning up the wiring harness , relocating the coil packs and looking at deleting the brake booster to clean the truck up a bit. What's everyones opinion on deleting the brake booster? What about wheel speed sensors? Heard of people wiring up e fans on the ac switch... Do you use the 12v going to the high or low pressure switch to signal a relay to turn on the fans or what?
    99 rcsb silverado...... boosted.
    Ponca City
    I'm no help. But interested. I pulled all the harness out from under the hood and helped the looks alot
    Slowest in Oklahoma...
    Sep 2011
    Also can the park neutral indicator and all trans wiring (except the vss ) be deleted since I'm running a th400?
    Sep 2011
    Bump
    Hydro boost looks a lot cleaner than the booster, plus still having power brakes just maybe make up some nice stainless lines. If you delete ABS you can delete the wheel speed sensors.
    Sep 2011
    Thanks frenchy ! I forgot about hydro boost, just found a write up on how to do it over on pt.net. do you know anything about deleting all the trans wiring ?I know the prdnl switch has to be in park to crank, but is there a wire I could tie into and make it think that its in park?
