Results 1 to 10 of 10
Thread: LS3 throttle body and 2002 PCM?
    Jan 2013
    I changed my setup just a little with L92 heads which require the truck LS3 intake manifold due to the square ports - my question is - will the LS3 throttle body work with my 2002 PCM?
    Pittsburgh, PA
    unless your drive by wire then a 02 pcm has a cable TB which isnt the same as the ls3 tb
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Jan 2013
    Yeah my truck is drive by wire
    Pittsburgh, PA
    has traction control?
    412 Motorsports
    Jan 2013
    Yes it has traction control
    Jan 2013
    I'm gonna get in touch with az dyno chip here in tempe and see what they say - I think nick d still does there Chevy stuff.
    you'll need the tb conversion harness. 6pin to 8pin.
    Jan 2013
    Thanks! Just got off the horn with my local tuner and they said the same thing. Much appreciated!!
    Jan 2013
    So here the adapter
    http://www.summitracing.com/parts/cei-108115
    And you must use an LS2 throttle body. The LS3 style TB's apparently dont work with the swap.
    Oct 2003
    Navarre, FL
    I just ordered a X-Link from torque rush, they are supposed to work with the LS3 throttle body.
