Results 1 to 9 of 9
Thread: 1998 Silverado 5.7L to 6.0L LQ4 modifying stock harness
    Jan 2013
    First off let me say that I have searched and can't find what I'm looking for. I have a 1998 Z71 with the 5.7L and I wanna swap in a 6.0L, I haven't done the 0411 PCM swap yet. That is one of the next things on my list. So on to my question. After I do the 0411 swap and finish building my 6.0 can I modify my factory harness or do I have to get a harness made?? I thought I found a thread where someone said you just have to cut and install a handful of connectors over the LS style and change the injector pigtails.... But seeing how I can't find it again. I'm starting to think a either dreamed it or made it up in my head while day dreaming. lol any help would be awesome thanks.
    Sep 2012
    Quakertown, Pa.
    Rather than modifying your factory harness, can't you buy a used 4.8, 5.3 or 6.0 harness and modify it for your truck? That's what I did. It took some time but it was worth it in the end.
    All the information I needed plus the PCM flash I got from this site: http://lt1swap.com/2000harness.htm
    John
    Jan 2013
    Well I was planning to do the 0411 pcm. Should I just save my money and go another route??
    Jan 2013
    I'm wondering if I can just do the 0411 PCM swap and change the connectors I need to on my factory harness ie. fuel injectors, knock sensors, cam and crank position sensors and so on... Thanks for any info
    Sep 2012
    Quakertown, Pa.
    By the time you do all that, you could have the proper harness to run the engine. For instance, I found a couple local ads on CL with a harness for sale:
    http://cnj.craigslist.org/pts/3632898270.html
    http://jerseyshore.craigslist.org/pts/3604785384.html
    Perhaps a similar search in your local area will yield some results.
    To me, time is money. The less time you spend trying to make your own harness, the more time you will have to enjoy driving the truck. Good luck with your project.
    My hat is off to you in attempting to make your own harness. Even reworking a stock 4.8/5.3/6.0 harness to work in another vehicle can be a formidable task to some. But I feel that it is still easier than trying to rework a Vortec injected 350 harness.
    John
    google
    gm performance pacific forum
    clink on first link
    find a member there named LEXtech he can help you
    I am at work it will not let me copy and paste
    very very true...swapp 411 and your 8-10 wires away from running
    Jan 2013
    Which is better to run?? A returnless system or the factory return line on the fuel rails?? which is easier and the pros and cons or each?? thanks.
    Sep 2012
    Quakertown, Pa.
    Not sure about the pros and cons of each. Whatever your engine has I would run. If it has a return, just use your original fuel line plumbing for the install. If it's returnless, just cap off your existing return line.
    John
