Results 1 to 10 of 11
Thread: Help with preparing for a swap
    Jul 2012
    Mansfield, TX
    I will be swapping my lm7 in my '00 silverado for another LM7 out of a '02 silverado.
    Is there certain things i need to buy before the swap?
    Is there anything I should look out for?
    What's the best method?
    I've heard you can just pull the tranny/engine in one or is if easier to simply unbolt the bell housing.
    Things I might run into?
    Just any hints or tips would be great.
    That's the truck I'm doing the swap in
    Jan 2012
    DFW, TEXAS
    its the same engine, i see no issues. remove and replace
    Apr 2011
    x2.. I would just clean up the bay and stab her in.
    be sure and pb all the exhaust bolt days before u do the swap
    2006 Silverado aka (Bad Bitch)
    K&N CAI, Diablo Predator, muffler delete, and a vette servo. 14.7x @ 93 mph (sold)
    1998 SS Camaro aka (Silver Bullet)
    LS6 intake, ported TB, LTs, ORY, cut out, and a pantie dropping tune by Nelson. 12.6 @ 110 mph 327 hp 347 tq
    2011 ecsb silverado aka (silver sleeper)
    forged 6.2 and a small snail
    Jul 2012
    Mansfield, TX
    Thank you,, this is my first swap so im just trying to prepare for it, ill be doing/starting on Feb 9th. If all goes well how long do you think it should take me?
    Jul 2012
    Mansfield, TX
    also what year range will fit in without modification. ive read i can use 00-04 LM7, but just double checking
    You can use any ls motor. You can do it in a day if you're mechanically inclined.
    Oct 2008
    Shawnee, Ok
    They're simple to pull. A buddy and I pulled three motors and installed two in a weekend. Probably would've been done sooner but I'd had to step away a few time before i started chunking tools.
    02 chevy 1500 ecsb. 02 lq4 6.0, nelson tuned.(sold but still in the family)
    89 chevy 1500 rcsb -under construction-
    Jul 2012
    Mansfield, TX
    well i picked up the motor today just had some more questions i got one out of a '02 tahoe. this one came with Electronic throttle should i swap over my intake and fuel rail with throttle body or what would i need to do to run it with drive.wire.
    ill get more pictures if yall would like just tell me what you would need to help me out.
    ALso got one with #862 casting heads are these any good im not sure what i have on my other LM7
    Swap your throttle body over.
    Jul 2012
    Mansfield, TX
    didnt think of that man, thank you
