Results 1 to 8 of 8
Thread: Electrical bugs
    Feb 2011
    Sevierville, TN
    Electrical bugs
    OK, my 05 GMC is starting to get some wierd electrical bugs. It's nothing too serious now, but I'm afraid it's going to. Today, the rearview mirror, which has the compass, temp, auto dim, and passenger airbag on/off indicator would go dead. It's rained all day, and only the airbag indicator would blink when the wipers would reach the top, just before going back down. I could shut it off, and back on, and everything would come back on and work, but the next time I got in, it would mess up again.
    There's also been some wierd noises coming out of the dash the past few months. It's like clicking and bumping noises. It only does it when the truck is running.
    Any help or advice would be great.
    Matt
    Thanks to all American soldiers for their service and sacrifices.
    Nov 2009
    SAN ANTONE
    sounds like a ground issue
    Feb 2010
    Central Texas
    +1 but don't rule out a bad positive connection, start at the battery and work your way thru.
    Feb 2011
    Sevierville, TN
    I've heard that a low battery can cause odd issues like this. Can anyone confirm this? My charging system seems to work fine, but I've noticed the lights dimming when any load is applied, even as much as turning up the radio.
    Matt
    Racoon Twp., PA
    Start with a multimeter across battery terminals. Idle should be 12.5-13, and around 3K RPM should be well over 13 volts, up to 14.5'ish.
    2013 CC 5.3
    81 C10 LS1 project
    Jan 2012
    Anacoco, La
    Ya that causes problems to, u haven't checked voltage yet?
    Jun 2011
    Clarksville, TN
    Check for rodent damage on harness too. But sounds like either bad ground or corrosion on connections
    Aug 2011
    Mabank, Texas
    Quote Originally Posted by demonheavymetal View Post
    +1 on the rodent damage, seen that before. Squirrels are notorious for it around our area.
    2002 Chevy Silverado 2500 HD. CAI, 4.10's, 35x12.50 r17 Kumho Road Venture M/T's. Nelson Tuned.
    2002 Z28 Camaro- Small budget cam build. Full bolt on, Custom grind Comp Cam, LS6 intake, 4000 CircleD stall, Nelson Tuned.
    2008 Dodge 2500- H&S MiniMax, CAI, DPF delete, EGR delete, AirDog fuel system.
