Results 1 to 9 of 9
Thread: built th400 continued...
    well as some of u know i got screwed on a which was suppost to be built trans...and some of u can care less and just want to talk shit,give a hard time,be immature whatever,gtfo...heres a lil show and tell ...
    broken drum
    and a ((stock)) 16 element sprag
    here the piston on the left is correct,pointing at the bleed hole.the right one is the wrong one!that piston did not match the drum,which caused an absolut seal causing the drum to crack...
    here in this pic,an old 70's pick up tube which is too short for a deep pan,causing the pump to run dry because it was sucking fluid from up top.
    heres the right tube and parts
    proper pick up for deep pan
    new Red Altos clutches with kelene steels unlike the stock ones that were previously installed
    New 34element sprag!
    torrington bearings
    theres much more in this newly built trans its amazing the knowledge these guys have.
    pissed off but glad im the right hands now.Yes it sucks it had to be like this but i cant burn anyone more than what i have been.
    Its definately not over...
    In for whats next!
    Seems the new trans will be a beast!
    Jan 2012
    DFW, TEXAS
    ummm... tko 5-speed. it'll bring out the true talent of gettin down the track.
    looking good! Thats a lot of the same parts in my th400. Did he get a 6 clutch drum? Mine came with a 5 clutch but certain years had 6 clutch drums. My tranny builder found me one on the interwebs
    Nov 2009
    SAN ANTONE
    thats where true experience comes into play
    Yea experience is priceless. My tranyy builder has been in the business for 29 years.
    Quote Originally Posted by o2camaross View Post
    Think Zach said this new guy has nearly 4 decades!
