Results 1 to 10 of 11
Thread: 11.42 @ 116.9 1.62 60' Extended Cab Truck
    At Amarillo 10/6.. 2000 ext cab weighing 4920..
    -Tyler 2000 ECSB-370-Vic Jr-FAST 4150-244/248 .612/.615 112 lsa
    This pass was with a NOS Bigshot plate.
    New plate I'm putting on this week is a NOS Double Crossbar plate.
    That's moving man! How big of a shot?
    Oct 2011
    San Antonio TX
    Quote Originally Posted by dirt track racer 81 View Post
    Holy crap that looks cool. Congrats on the run.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    .082 jet
    Sep 2006
    THE 405
    The truck could probably run .20s to .teens on that same jet with some work and better weather. The tuneup was still a little fat and we were still pretty conservative on timing.
    Hopefully with the new plate and more nitrous and lots of tuning, we can get this land yacht down in the 10s. Then later on with a better cam more suited to the combo, we can go a little deeper.
    Real proud of this truck and happy for Tyler. It's been a long time coming
    That's hauling ass in a ext cab
    Congrats tyler, good to see it making passes again.
    May 2005
    What kind of power are you making?
    ●01 silverado x-cab w/5.3 ● STS GT-67 ball bearing turbo kit(relocated under cab)● Comp 918's ● Comp Hardened Pushrods ● Comp Cam 212/216 .557/.561 114 lsa● 42lb injectors●Walbro 255lph inline●OBX Intercooler● YANK 2600● Nelson SD Tune● Magnecore 8.5mm wires● STS meth Injection●Comp valvesprings● 05' e-fans w/ 34" radiator● ARP rod bolts and headbolts● NGK TR6 plugs● Eaton Posi● DB Rods bagged 4 link● FLT lvl5 4l65e● Apexi AVC-R boost controller ● z06 6 piston brakes front/4 piston rear 14" rotors ● Goodrich SS brake lines● powdercoated frame
    Oct 2012
    del rio,tx
    trucks are meant for hauling.........hauling butt!!!!
    robzilla
