Here is a pic of the truck I am working on.
AND the motor and trans I bought.
http://www.ebay.com/itm/221110863177...ht_2140wt_1165
Welcome, sounds like a fun project
04' RCSB, LQ9, Front mount T76, TU1, Circle D 3K, Built 4L60E, True Trac, 3.42:1, 4-6 Drop
Someone posted a big thread about a Dakota swap at LS1Tech in the conversion section a few weeks back. They said it was one of the easiest swaps out there. I can't wait to button up my LS1 S10. I'm shooting for mid 11s on motor but I'm running a baby cam honestly.
2005 Silverado SS AWD
AEM CAI, ARH LTs, HD-2 shift kit with vette servo, Circle D 278mm 3200 stall Madtunesracing.com street tune (MTR now has a Dynojet 248 chassis dyno)
13.82 @ 94.92 w/1.83 60'
That'll be a fun project indeed, keep us up to speed with updates how everything is going, looking forward to this swap!
Here are pictures of LSDAK1 with the fully dressed motor. We are waiting for the driveshaft, then off for wiring.
Specs:
2007 LY6 103k stock
6L90 transmission
Rear disc conversion
255 in-tank Walbro with 58 PSI regulator/return 3/8 feed, 5/16 return
All stock gauges except tach
Drive-by-wire accelerator pedal
Stock column shift
Original crossmember with spacer
Original motor mounts and perches with adapter plate
5" aluminum 1-piece driveshaft
excellent build
You plan on keeping it with the stock exhaust manifolds or going to a header at some point?
Looks like it should be a fun little truck!
T-RAV99 GMC | 5.3 | Skinny White Guy Tuned
