Results 1 to 10 of 13
Thread: Need some help
    May 2012
    Floresville
    Need some help
    I am looking for 1/2 ton truck rear ends from 2000 on up. I do not need
    Any of the internals axles, differentials, gear set ect. I am looking to
    Take them wrecked used trashed don't really care in what condition.
    Please help me find them I will pick them up if you are local.
    Send me a p.m.
    May 2011
    Buffalo, NY
    ummm, wtf? damn spammers
    Aug 2004
    Magnolia, TX
    Quote Originally Posted by Slow08 View Post
    Lol, he's not a spammer. Actually builds rear ends.
    wichita falls, tx
    Yeah I believe he is a supporting vendor and he has posted quite a bit before.
    S.A. Texas
    umm damn Yankees
    May 2012
    Floresville
    Lol I'm not a junk yard man...lol
    I'm starting to produce bolt in 9" and Dana 60 differentials
    But I need the old brackets off the originals so it's a stock fit.
    No body makes these brackets for the 99 on up so
    I half to graph over. The originals...
    But any differential with in the year models I posted
    Will be greatly appreciated..
    Round Rock, Texas
    You can't get spring perches and weld them on? Same with the shock mounts, get a metal shop to cut some brackets out of 1/4" plate and weld them up. And once you get your jig setup, it won't be a problem cranking them out.
    I have a stock 1998 10 bolt. CHEAP like dirt cheap, if you want it..
    May 2012
    Floresville
    Yea I can and I have made them my self
    but it Takes time to make the shock bracket,it's the 07
    And newer that have a curve to them that I don't like making.07 and older
    Are easy to make, its just easier to cutt them of a junk
    One and put them on a new build. I usually take a core
    When I build one to do so, but as of now I'm all out.
    Round Rock, Texas
    Gotcha. Good luck with your search.
