Results 1 to 10 of 31
Thread: 408.Luke's Silverado SS for sale
    Houston
    Ok guys the SSS is up for sale $35,000 OBO
    2003 Silverado SS Black
    Just under 130,000 Miles
    Im posting it here first, if there are any question please feel free to email me at luketrueheart13@hotmail.com or PM me. Ill be posting this up on the other forums and ebay within the month. Ill also get a better parts list and general pictures on Thursday/Friday
    the 2 track vids (same pass) trap was just shy of 130 and less than 1/2mph off from being the fastest SSS on its FIRST EVER (and only)PASS.
    I believe low 10's 135+ trap is possible with the shot i had in the vids with good traction.
    2 Soon Jr plates not included
    This is a highly modded truck and will need a full tune for the engine and the nitrous, the current motor tune in it is Fine for E-85 WOT and is ok at part throttle, i just never bothered to dial in the stop and go bits so it will need to be fully tuned. I should be getting the rino lining touched up this week and Ricky will be giving it a full detail. The back seat is included but not installed (nitrous bottles are there) I am also selling my 20ft car hauler with the truck if buyer is interested along with my duramax (ill give you a sweet deal on all 3) Car hauler is 20ft w/ 4ft dove tail and larger 2 5/8'' ball, 6 lug 5200lbs axles (each) ramps, and straps. Duramax is a 04.5 RC/LB white LLY.
    Exterior
    - front and rear windshields are new
    -the paint isnt in the greatest condition, im going to see what Ricky can do with it but there is a large scratch on the hood and a few other here and there. The truck lived in Wyoming for over a year and it shows a bit but hopefully ricky can get most of it out
    Interior
    -Mostly stock, has A/F gauge in center console area. Top of center console has N2O psi gauge and a areoforce with 5v sensors for fuel and oil psi.
    -Rear seat not installed, two 15lbs bottles in its place
    -Window Switch and relays are hidden behind the knee panel under the steering wheel and easily accessible.
    Motor HKE 408
    -HKE ported L92's
    -Ported Edelbrock L92 Vic JR
    -Wieseco pistons
    -eagle rods
    -Callies C-Series LS1 4.000 Crankshaft 24 tooth
    -EPS speced cam
    -ACL bearings
    -ls7 lifters
    -DBRods custom elbow
    -102 Nick Williams throttle body
    -4 1/2'' intake tube with huge aem air filter
    Century 4L80e Stage 3+
    -Tons of parts can provide more info if interested
    -4400 Stall Circle D converter (may need to be re-stalled for high nitrous application)
    -TCI Deep pan
    -40k trans cooler
    Nitrous Outlet Direct port
    -Plumbed by DBRods
    -4 Noid setup (each bank has n20 and fuel noid
    -two 15lb bottles
    -Feedline -6
    -NOZ window Switch
    -Lingenfelter Timing controller
    -Nitrous PSI gauge
    -Stand alone fuel system for the nitrous
    -60lbs injectors
    Fuel System
    -DBRods custom 20 Gallon Fuel cell
    -areomotive A1000 pump
    -pre and post fuel filters (100 micron pre and 40 micron post for e85)
    -8 feed and -8 return. cell has two -10 outs from sump
    -Stock sending unit in fuel cell
    Moser Fab 9
    -35 spline axles
    -Nodular 3rd member
    -spool
    -Moser Fab 9 housing
    -4.10 gears
    Suspension and chassis
    -DBRods 4 link out back
    -RWD converter
    -Strange coilovers on all 4 corners
    -5 lug converted with new front wheel bearings (5x4 3/4 bolt pattern)
    -Factory looking wheel tubs
    -DBRods tubular lower control arms
    Wheel/tiers
    -Front 18" ZR1 replicas
    -Rear 18'' ZR1 replicas on 305 45/18 MT et street II's
    -Rear 15'' Jegs 5 stars on M&H 390's
    Exhaust
    -DBRods custon 2'' primary 3 1/2'' collector long tubes
    -3'' pipe with a x-pipe and two 16'' magnaflow mufflers
    Arizona/Utah
    Wow what happened? Why you selling all your toys? First Kurt now you? Seems like every one down there is getting out of the game.
    Houston
    Getting transferred to Australia
    Oct 2011
    San Antonio TX
    Time to start messin with some Holden Monaros lol. Seen this truck at ls1 shootout, its badass. GLWS
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    Glws! Beautiful and fast aSS truck!
    Houston
    Im just kidding about Australia BTW
    Feb 2011
    LaPlace, Louisiana
    How much for the license plate? lol
    GLWS man, hope it goes to somebody that takes care of it like you want..
    Run your motor, not your mouth..
    04 ECSB 5.3 Sierra: 14.6@95
    Pacesetter Headers, Intake, Tune
