Results 1 to 8 of 8
Thread: Fuel rail question dual to single
    Sep 2011
    Here's my situation, I have engine in from a 05 avalanche that has the single fuel rail, my nelson harness is for a drive by cable so the newer style injectors will not work, can the single line rail be used with a drive by cable intake and the older injectors
    I have the intake with cable throttlebody on the truck, I was wanting to go with the single rail fuel line and use the corvette filter instead of dual lines at the intake
    any of those items you mentioned can be interchanged, you can use any throttle body you want, returnless or return style rails, injectors, etc.
    if the harness is dbw, of course use the dbw tb.
    any of the other things dont matter.
    Dec 2010
    Only catch may be tuning for the correct regulator (vac referenced vs not)
    Aug 2011
    Galveston, Texas
    Nelson sent me the correct connector for the Flex fuel injectors. (stock on a 05 avalanche) I soldered them on and haven't had a problem since.
    1992 Full size blazer 5.3 Swap successful.
    http://www.ls1truck.com/forums/lsx-t...zer-build.html
    Galveston, Texas
    Sep 2011
    Thanks, my concern was the fuel rail, I have a complete drive by cable intake setup, just making sure I could use the single line fuel rail on it
    Jan 2012
    Anacoco, La
    My truck is an 04 with a 2000 6.0, the truck has the duel fuel line n a single line injector set up it runs, but is that goin to make problems?
    Quote Originally Posted by bootlife View Post
    you can use either intake manifold to make your setup work.
    '04 usually have a single feed line with the return and regulator in the tank.
    If that's the case, use your 2004 intake manifold, the 2000 model 6.0L won't know the difference.
    Jan 2012
    Anacoco, La
    Problem fixed lol I just picked up an 05 vette intake and coil covers for 175
