Results 1 to 9 of 9
Thread: Tac module and gas pedal
    Oct 2010
    Southern California
    If I mount my tac module to my firewall, wheres the best location to go through to the gas pedal?
    Dec 2010
    My vote would be where the throttle cable comes through.
    Nov 2009
    SAN ANTONE
    What year vehicle are u doing the swap on
    Oct 2010
    Southern California
    Its a 95 GMC Sierra.
    Jan 2012
    Petal, Ms.
    I went where the old cruisecontrol wires entered the firewall
    Oct 2010
    Southern California
    If I enter through the hole where the gas pedal cable is, where's a good place to get a grommet?
    Oct 2010
    Southern California
    I'm going to try to drill a hole where the gas pedal cable comes through the firewall. Here's a picture of the DBW cable and its size. I need help finding a rubber grommet for it. It looks to be a 1" 3/4 diameter. Any help would be great.
    Jul 2010
    Douglasville Ga
    A cleaner option is to not drill the hole that big. Instead d-pin one of the connectors. Then, the harness will fit thru a small hole. Once they're thru, just repine it. Doesn't matter which end you d-pin but id recomend doing the tac connector just because its a little easier than the pedal connector. Good luck!
    Jul 2010
    Douglasville Ga
    Actually, I think both ends use metripak terminals. If you haven't depinned these before, a piece of welding wire sharpened to a point works decent as a release tool.
