Results 1 to 10 of 35
Thread: some notes from a beginner, change rings or change pistons?
    Question some notes from a beginner, 5.3 to 6.0 swap
    as some of you know a blew the 5.3 and bought an LY6 6.0, well, today as i was cleaning the engine and checking the block/ rotating , i found that the pistons have some very low but noticable play when you push them from front to back,
    also the rod bearings look like they have a little ware , should i change that too?
    the last thing is that the first cam bearing have copper colored spots, change or leave?
    here are the pics:
    here is the cam bearing
    bore was smooth with no signs of ware
    the block was in great shape acctulay very slight rust consdering its a 2008 and the junkyard was close to sea!
    so what do you guys think?
    Oct 2007
    Bandera, TX
    Run it. U will be ok
    single digit street truck
    for build info
    Mar 2011
    Hamilton, Ontario
    really is personal preference. but if your that far in what is a set of bearings worth for piece of mind and its already apart.
    orderd some parts from summitracing.com damn the shipping is killing me:suicide:
    Your Order
    Purchased items
    Part# Item Price Qty Line Total
    ARP-234-6301
    Connecting Rod Bolts, Pro Series Wave-Loc, 2000 Alloy, Chevy, 5.7L, Kit
    $116.51
    1
    $116.51
    ARP-244-2901
    Flexplate Bolts, Pro Series, 11mm x 1.5, .880 in. Length, Chevy, 4.8, 5.3, 6.0L, LS1, LS2, LS4, LS6, Set of 6
    $21.79
    1
    $21.79
    CLE-CB663HNK
    Rod Bearing, H Series, Coated, Standard Size, Tri Metal, Chevy, Small Block, Each
    $16.95
    8
    $135.60
    CLE-MPB1
    Plastigage, .004 in.-.009 in./ .102mm-.229mm, Range, Blue
    $1.95
    4
    $7.80
    CLE-MPR1
    Plastigage, .002 in.-.006 in./.051mm-.152mm, Range, Red
    $1.95
    4
    $7.80
    CLE-MPY1
    Plastigage, .009 in.-.020 in./.229mm-.508mm, Range, Yellow
    $1.95
    4
    $7.80
    CLE-MS2199HK
    Main Bearings, H Series, Standard Size, Tri Metal, Chevy, 4.8, 5.3, 5.7L, Set of 5
    $199.95
    1
    $199.95
    DUR-CH-23
    Cam Bearings, Bi Metal, Chevy, 4.8, 5.3, 5.7, 6.0L, Kit
    $21.99
    1
    $21.99
    FRM-XP5245
    Spark Plug, XP Xtreme, 14mm, Tapered Seat, .708 in. Reach, Projected Tip, Resistor, Each
    $5.95
    8
    $47.60
    PPP-20-265S
    Cab Roof Lights, Chevy/GMC, Smoke Lens, Amber LED Bulbs, Set of 3
    $117.95
    1
    $117.95
    Part Subtotal $684.79
    Order Charges
    Additional Shipping Charge $108.94
    Delivery and Handling Charge $12.95
    Order Subtotal $806.68
    Total Charges $806.68 USD
    Live Chat Available Tuesday - Friday
    9:00AM - Midnight
    (U.S. Eastern Time)
    Receive the latest offers by email Sign up for Email or Request a Catalog
    Feb 2012
    Mcalester ok
    Glad to see you went ahead and ordered bearings...... As 89serria said that the piece of mind is worth it specially since it's already disassembled
    Quote Originally Posted by Slowcrewcab View Post
    yeah , id rather pay for the pace of my mind than pay for another motor
    Q: will this CB663HNK fit my LY6 or should i change to antoher part number
    Feb 2012
    Mcalester ok
    Quote Originally Posted by sand man View Post
    I believe they should from what I read on em....I'd defiantly check the measurements with a mic
    the GM#12493714 is the same for 2003 ls1 and 2008 LY6 so i think these will fit
    Feb 2012
    Mcalester ok
    Think you've answered your own ? There. Have fun with the build!
    will buy paint,piston rings, well tray to paint it tomorow, looking at this color
    or should i paint the intire motor with heads covers and intake
