Results 1 to 7 of 7
Thread: new Dyno number
    Jasper, Ga.
    After I installed the 80 mm BBK throttle body I showed a gain of 6 hp. Not bad I guess. 241 / 293
    1999 Silverado 1500 Ext. cab Red 2/4 hotchkis drop & swaybars, bilstein stocks, AR626 & 404 Nitto's, Yank converter, ASM headers, ASP underdrive pulley, Taylor wires , free mods VCN 2000, Nelson Performance tuning
    2002 Red WS6 M6; Flow master K&N
    not bad at all, i'm sure with more mods, more power will come.
    so what's your total power after the TB and the nitrous setup? i think i remember you getting it corrected, have you ran it yet?
    later,
    farmtruc
    Jasper, Ga.
    Did one run, like 310 /333 on full cold bottle. Just filled bottle before run. Tuning next on list with bottle warmer.
    Aug 2003
    Keller, Tx
    what shot did you run to get 310 rwhp? 50 shot i'd hope, and if it is anything more than a 50 shot you have a problem somewhere.
    02 silverado ext cab short bed|2/4 drop with HAL and cal tracs|ASM headers w/ duals| 4.10s w/ eaton|ls1 edit|FIPK|BBK|6.0 swap|230/236 .588/.591 113 comp|ported 6.0s 2.055/1.60s 918s|4L65 w transgo and servos|PY3600E|8.1 injectors|LS1 fans|TNT power ring wet kit
    Jasper, Ga.
    It was suppose to be 100 shot so I have a problem. I know this. I need to get it tuned and change spark plug gap. Other than that I don't know what else to do? What else can I check?
    are you getting enuff fuel or n20?
    how's your fuel pressure?
    Jasper, Ga.
    Have not check fuel pressure.
