Results 1 to 10 of 13
Thread: LIft kit Ideas
    Feb 2012
    San Antonio,TX
    LIft kit Ideas
    Are there any true 8" suspension lifts out there I have been looking and I am not having any luck..Also if I do 37x13.50x18 do I need to beef up the gears or will OEM be good???
    Sep 2011
    456 gears ftw!
    Oct 2011
    San Antonio TX
    X2^^^
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    Orono, ME
    I see on your one other post you say you've got an 04 Suburban, is that the truck you're inquiring about? There are a lot of variables when it comes to lift kits but a few I would recommend for the height you're seeking are the 7" Full Throttle lift, the 9.5" Full Throttle lift, the 6" Fabtech, or the 7" Cognito kit.
    2012 Honda Civic Si - DD
    Mar 2010
    Midland, TX
    ^^^ What he said plus options of a solid axle swap. ORU has some sick SAS Swap kits.
    - 5.3 Stock Internals - Cal Speed Stainless LT's - 18" Magnaflow - K&N Drop In - Airaid Intake Tube - Nelson Tune -
    Shopping List
    - Cam - 3200 Circle D Stall - 10" King Coilover Shocks - 16" King Reservoir Shocks - FG front Fenders - 17" Methods -
    Sep 2011
    Michigan
    Atleast 4.56 gears I have a 6" with 35/12.50/20s and I am thinking about 4.88s. The truck has the stock 3.73
