Results 1 to 10 of 17
Thread: tire question
    Jan 2012
    vacherie louisiana
    tire question
    i have a 99 z71 extended cab i just put a 6.0 in it and now i need some tires it is factory height on the factory rims whats the biggest size tires i can put on it right now and what kind of tires would be best i use it about 50/50 on the road and in the mud i need sumthing that will grip good on the road and have good traction in the mud
    Apr 2011
    East Texas
    Nitto Trail Grapplers are good
    Jan 2012
    vacherie louisiana
    whats the biggest i can put on ma truck stock height and factory rims
    Aug 2004
    Magnolia, TX
    I think you can fit 285s if you crank the t-bars.
    Lt285/75R16 or 285/70R17 depending on you stock wheel size.. Will fit no problems, maybe a minor tbar adjustment. They might rub slightly at the rear plastic inner fender, but you can tie that back a bit and no probs etc.
    Mar 2006
    Indy
    I have a 2000 year of the same truck and I had 305s on it. At the time I had the t bars cranked a few more. But 285s fit just nice. 305s were cutting it really close on stock height. I think it was 305/70.
    Jan 2012
    Anacoco, La
    30s will go with no rub, I did 32 jacked the t bars with very lil rub, I have 305-65-17s pro comp Xtream MTs, mud grips will get u stuck faster but look good, also with my set up I found the weak links pretty fast lol
    Jan 2012
    Anacoco, La
    Also I did a 3in body, t keys n blocks to get 6in up. I love it not to high not to low. I have a vid on u tube of it look up bootlife 2000 silverado. http://youtu.be/uNdJPLlmABQ
    Mar 2012
    west bend, wisconsin
    im a fan of the bfg all terrain in 285's. I used to work in a custom truck shop in AL and alot of guys ran the nitto trail grappler or the mickey thompson Baja MTZ or their baja ATZ both look really good and wear well on light trucks. also im a fan of the toyo open country MT. hope this helps.
    1999 chevy silverado Z-71- 5.3, CAI intake, catback, nelson tuned, lpp lt's, vette servo, e-fans.
    Sep 2012
    31-10.50 but it will rub when put in a bind. 295-75 but it is all up to u!
