need the spring anchor plates (mount on bottom side of axle tube) and the spacers (mount between ubolts and top of leafs) to fit 3/4 ton 14 bolt SF w/6 lug..............cant use the rusty brand...already got those models.......thanks
 WTB  3/4 ton/14 bolt SF spring anchor plates and top u bolt spacers
'93 Chevy Sport... LS2...T56 Magnum..."Red Rider" under construction.........
 WTH JUST HAPPENED?
						WTH JUST HAPPENED?
						I used the 1/2 plates when I went 14 bolt, had to grind the radius out a little bit but they worked fine even with me hitting a 300 shot on them.
 WTH JUST HAPPENED?
						WTH JUST HAPPENED?
						it was off a little bit. I really had no choice but to use the 1/2 plates since they had my caltrac mounts welded to them. Most people recommend to get new ubolts any time you take them loose since they rust and pit, plus they get bent and stretched as you torque them down.
 WTH JUST HAPPENED?
						WTH JUST HAPPENED?
						I didn't need the bars to stop wheel hop, only to help on my launch. I dropped about .2 on my 60ft times with them. I haven't tried the Assassin bars but I wouldn't blink an eye to go fo them, they look slick.
Anybody got these parts kickin around??
 Senior Member
						Senior Member
						you can get them from 4 wheel parts
Hand p&p heads, 219-227 .607 .613, pacesetter, tbss intake, 92mm t-body, cai, e-fans, 14 bolt, 4.56, true trac, pi 2800, 33's, 4l80e built by me
In the makin
Boost.
