Results 1 to 10 of 25
Thread: my 72 c10
    Jan 2012
    Broussard, La.
    my 72 c10
    i bought a 72 c10 and a 01 5.3/4l60e to put in it. now what?
    Should be fun
    Jan 2012
    Broussard, La.
    no one has any input? i need the info on the little things. i know i need a ecm flash, wiring harness, and a different oil pan. i was wondering what are some of the little parts im prob not thinking about.
    Apr 2006
    Bellevue, Nebraska
    Quote Originally Posted by kellyp View Post
    Well, you didn't really ask a sPecific question. It's a cool lookin project. So what are your questions? I'm sure a lot of us have opinions/suggestions on what you should/could do next.
    Arizona/Utah
    Dirtydingo motor-mounts
    Nelson tune
    schnofield long tube headers
    efans from a 96 ford windstar
    I think grey coys and some nice street tires
    smooth out the body and paint it black granite metallic.
    Jan 2012
    Broussard, La.
    Nelson tune
    i have headers already not sure what kind they came with the motor. my porterbuilt xmember came with motor mounts. i am seriously considering coys in gunmetal or boss 338s. the truck will be red with a white top similar to the way it is now.
    i will def look into the efans tho.
    Dec 2011
    indiana
    Nelson tune
    Not to be off topic but have you see the new Caddy paint called Black Diamond tri coat? I saw it at the auto show this year, BEAUTIFUL!!!!
    The headers you got with your motor may or may not fit since they werent made to go into that truck body. I would do some measuring to make sure you dont need a different set. You will probably have to get your driveshaft modified to fit as well. Not sure if it will need to be shorter or longer that will depend some on your motor mounts. The Dirty Dingo mounts give you some adjustment both ways.
    Jan 2012
    Broussard, La.
    Quote Originally Posted by AFSP1211 View Post
    i was wondering what little things im gonna need to make this work in this truck as far as gauges and stuff like that goes.
    i know im gonna need a fuel pump and filter setup, what is a inexpensive setup?
    stuff like that. im sure once i actually start the swap i will have more specific questions.
    Nothing else needed. S and p makes a nice cover for the threads
    Jan 2012
    D/FW
    just leave as is....no nut needed.
    good luck with the project...should be fun!
    1968 GMC - Carb'd and cam'd 6.0 LY6, 200-4r, 3.73 posi 12 bolt
    2006 TrailBlazer SS - 13 sec. grocery getter
