Results 1 to 7 of 7
Thread: Dirtydingo mounts obs with ls 5.3
    Who all used these mounts I must say they look great out the box till you unload them and bolt them up.I'm wondering why it took me 5 hours to pin my motor In my suburban and why i paid that much for something I had to centerpunch and notch the holes b/c nothing lined up
    Everyone else seems to like them.
    May 2010
    Galveston, Tx
    Interesting...I'm sure these aren't hand made so if one set is wrong then they're all wrong.
    My TD plate adapters worked just fine though
    95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
    I got it to work but had to Redrill and slit holes on both sides to get the bolts threw absolute nightmare I was fixing to cut them and re weld them. No comes the fun part the wiring should be a snap though
    Rockwall, TX
    Mine worked out fine, no problems here.
    1989 RCSS 5.3/4L60E swap
    - 224/230 .581.591 112lsa,
    - 3200 Stall
    - DJM 4/6 drop
    - Nelson Tuned
    i wonder if they sent you the wrong one's? i didn't use they on my swap but everyone i've talked to that has loves them.
